Timberline wood stove model
Lea
3
Virginia
Hello everyone,
How can I determine the model number of a Timberline double door wood stove? It was in the house when we purchased the house.
Thanks in advance for your help!
[Hearth.com] Timberline wood stove model
There are 3 "T" (Timberline) models which are single door and go by wood length or depth, T-18, T-24 and T-33. There are 3 "F" models for fire viewing which is what you have. The three TF (Timberline Fire) models are T-PF for Petite, T-SF for Small and T-LF for Large.
By the width of stove front showing from door to angle iron, you have the smaller of the two larger double doors, or the S model.
If you need this for installation clearance to combustibles, simply go by the NFPA 211 Standard for unlisted stoves. This gives reduced clearance to combustibles down to 12 inches with proper heat shield.
Reactions: begreen
Thank you. This helps immensely!
I should have linked the manual for you. There is also a picture of the Large stove here. Notice how much more space from doors to corners. The doors were the same size, used on a wider stove.
Manual Pdf at bottom;
If you're going to use this, you may have clearance concerns (distance to wall) if that wall is combustible material behind it.
Hi,
I saw a small double door Timberline stove the corners of the stove were bent not angle iron corners. There was a large Timberline stove next to it that was around 10 inches wider. What model was I looking at ?
Thank you
