tips on moving a wood stove?
mama23
13
Leavenworth, WA
ok - might seem silly question.
looks like we might be purchasing a used jotul black bear. weighs 320# or so. how does one move one of these things? we have a truck & would be able to transport that way, but honestly can't quite figure out how to get it in there.
any tips or tricks, greatly appreciated.
Get wheels under it. Cut a piece of plywood a bit larger than the legs' footprint. Center the stove on the plywood. Take a regular appliance dolly and slip its lip under the plywood. Take some cardboard or a blanket and put it between the stove body and the dolly. Now take a ratchet strap around the stove body and the appliance dolly. Ratchet the strap tight to make one unit out of the stove and dolly. Now moving it is a piece of cake.
Thanks @begreen .
I heard you are the resident yurt expert. would love some advice on that as well. we are in the same neck of the woods - am on N. puget sound, but yurt will be in E. WA
Thanks @begreen .
A friend owns the yurt up in Concrete. My expertise is limited to exactly one installation.
Reactions: mama23
Sounds like an experience base building here.
Reactions: mama23
Get an easy breathing stove. Yurt chimneys are short.
Reactions: mama23
It means a stove that works well with less draft. Most stoves are tested and designed to work with a 15-16 ft flue. This is to get enough draft to pull air through the primary and secondary manifolds. Not sure about the F118CB, it's an uncommon stove. The early ones had problems and I haven't heard much about them since. The original F118 was a strong heater and not very fussy about chimney height. The other thing to think about in the yurt will be clearances. In a small yurt this becomes pretty important. One stove that should work well would be the Pacific Energy Alderlea T4. It is cooler on the sides and will work with a 12ft. flue.
(broken link removed to http://www.chimneysweeponline.com/pacaldert4.htm)
Reactions: mama23
I was looking at the alder lea as well - its beautiful. just a lot more expensive I think, as I can get the jotul used. - but that is important info to check into.
Would that used stove be the original F118 or the new clean burning F118CB?
How large is the yurt?
Reactions: mama23
