Hi! I apologize for this VERY lengthy post...but I need to pick the brains of you more experienced wood boiler operators out there
I am considering buying a TIS UNI boiler from Belkomin. I have some questions about sizing, buffer tanks, and chimneys that I hope to get feedback on from members. If you're not familiar with this manufacturer, it is a modulating boiler (30-100%) and "Belkomin boilers use natural gasification with two air supplies for primary (pyrolysis) and secondary combustion. Since it is natural gasification the bottom part of the boiler is freed and a considerable gain of 20% firebox volume is made available."
The current system set-up I have is:
-mid-western Ontario (the snowbelt!)
-boiler in the shop with 100' pex running to the house
-600 gal stainless steel, insulated, non-pressurized storage tank (but it has never worked right with this boiler)
-Heat exchanger/ forced air in the house, in floor heating in stone floor in kitchen, temp of house usually 69-70degrees
-1857 log cabin with good insulation, but needs new windows, 2500 sq ft.
-shop is 4000 sq ft, heated only to 60F max
-hot tub in house (plumbed to take heat off the system but not hooked up yet)
- 45,000 L (11,000 gal) pool that I 'may' heat
-there will be a DHW tank hooked up
- 100,000btu propane back-up furnace in house
-will be installing a condensing propane boiler in the future.
Now...
I recently purchased 3 pressurized storage tanks that hold about 1200 gallons each.
I am not going to get a Heat Loss Calculation done because a) it's too hard to find someone who will do it. They aren't interested in trying to assess an 1857 log cabin because they say it's too complicated and time-consuming and b) the few would who do it wanted thousands of dollars to do so (and honestly, I would rather put that money towards the heating system itself). Based on the Benjamin boiler I have now (which is really only intended to be used as a back-up), and heating sources I've used over the last 12 years, I am estimating that I need approximately 100,000btus for the house, and then an additional amount for the shop, so perhaps up to 130,000btus. Here is a chart showing dimensions of some of the Belkomin boilers (for the models not included on the chart I put some basic specs below.)
UNI 65: KBTU: 30-70kW 7319 sq ft
UNI 75: KBTU: 35-80kW 8395 sq ft
UNI 85: KBTU: 40-90kW 9472 sq ft
SO....Here are my questions:
Based on the info I have provided (I know there are other factors, but best guess!), what size of boiler would people go with?
What about the storage tanks? How many would people use? (I have 3 I can possibly use, 1200 gallons each.)
Would it beneficial for me to buy a UNI95 and hook up as much water storage as possible?
I know very little about the storage/heat transfer- (all I know is that I am sick of stoking this Benjamin every 3 hours and going through 50 cord of wood!).
I want to have to stoke it as LITTLE as possible...but I don't know if it would make sense for me to heat up that much water all at once.
If I had the house heat at 69 degrees, the shop at 60 degrees, DHW (one person), and I heated all three storage tanks (3600 gallons) to 160-180 degrees, can anyone provide me with a rough estimate as to how long it might be between firings?
Or is this overkill? (BTW...the tanks are going to be insulated with sprayfoam and stored outside (likely in a shipping container).
Would it make just as much sense to go with a smaller unit (UNI65) and only have one tank?
The main reason why I started looking at gasifiers in the first place was because I can't take the smoke- inside OR outside. I realize this type of modulating boilers will emit more smoke than a true gasifier, but I can't (won't) spend that kind of money on something that I STILL have to cut, split, stack, and stoke with wood! So, I figured a modulating boiler with lots of water storage was the next best option, as I could run it full out until all the water was up to temp, and then it would shut right down and there wouldn't be smoke while it was idling and there wouldn't be creosote build-up either. I'd appreciate hearing people's thoughts and opinions about all of this
Thanks for your input! Patti
Now...
