To answer your question from the thread we hijacked. I find that medium fan uses less than hi fan by a small amount ( at least till the house catches up) but the out rooms get better heat on high fan.. I see higher ramp up of flame with high fan on. I do not change settings other than that for overnight burn. I leave it alone. In this weather I will burn maybe 1-1/2 bags a day, could be two depending on pellet quality and wind ( in the 20's with a hi mid day spike of 32).. If it stays cold, Generally between high teens and high twenties last year I was burning that to two bags a days. From teens to single digits a steady two bags a day. Down around 0, 2-1/2 bags. The most I burned last year was three but we had 40 MPH winds and -6-+6 degs out. My house could be much tighter but it is a little tighter this year than last.!! I'm pretty sure at 1800 sq ft my stove works harder than yours has to Tony, so I'm not sure how much comparison you can take from all that !
And actually my stove just went into maintenance burn for a short time, pretty good. Speaking of which, long maintenance burns don't help pellet consumption, it can ramp up for heat and hold the house and use less sometimes. Depends how bad a ramp up it is.
Oh and I am running in Room temp manual, 72 deg. Feed rate 4.
