For an old non-EPA stove, What is the most effecient use of the a draft system that includes a draft on both, the top and bottom of the door?
Currently, I'm controlling burn rate only using the bottom draft. Should i be using the bottom draft to rekindle then switch to only the top after kindled to maximize heat output and burning off of volatile gas?
