Will be picking up my new Iron and Oak vertical/horizontal splitter by next Tuesday. The dealership is about 45 miles of smooth roads from my home.
The splitter will not fit into the bed of my pickup because the opening under the canopy is 39" and the splitter is 43" at its highest point and cannot be elevated, lowered or otherwise wiggled under the canopy. A friend has an open bed pickup I can borrow and the dealership can easily lift the splitter onto its bed. However, the real dilemna is how to get the splitter out of the pickup when I arrive home. It weighs 775 lbs(+/-). I have a couple of 10' long 2X8 loading ramps but they would probably break under that much weight.
Another option which the dealer uses when moving splitters to shows, etc is to tow it behind my pickup. The hubs, tires and wheels are rated for "high speed" highway use not exceed 35mph. My truck is set up with the necessary hitch, 2" ball, etc. Before towing, I would check tire pressure on the splitter and turn off the fuel lever on the Honda engine.
Would appreciate some recommendations from those who have solved a similar dilemna.
Best wishes,
John_M
Best wishes,
John_M
