I have an 1880's house I am looking to install a wood stove in. I was told a traditional hearth, with bricks, doesn't meet the k value requirements in the manual.
So I cut into the knotty pine with the goal of building my own hearth out of aircrete since the K value is really high and even with 3/4" I would be able to achieve the requirements listed in my manual. The problem is the existing stone hearth.
(view from top with some details)
(view from basement showing arch)
I am not sure of the structural strength of the archway if I were to remove the top layer of brick.
Thoughts / options I am considering:
1) Remove the top layer of brick, then pour aicrete to level to sub floor with a mix which is stronger than the mix I plan to use to insulate the hearth. Then place a thin steel frame down into the hearth space and pour my aircrete hearth and top with tile or something decorative.
2) Remove the whole archway and span between the two main floor joists on either side of the chimney and brace out to the existing header where the brick arch ends. I would also likely add extra bracing from the spanned floor joists to the joists one out from there to make it stronger as well. From here I could add a sub floor and start from there with a 3/4" hearth or go on to the next option.
3) Do #2 and remove sub floor at exposed area. Brace basement floor joists more and put down a piece of plate steel as a new "sub floor" then pour a deeper hearth (1-3/4") with aircrete providing an extra thermal barrier.
Thoughts? Any masons / carpenters out there? This is an 1880's balloon framed house with true to dimension lumber featuring large beams / posts throughout.
![[Hearth.com] Traditional Hearth Modification questions [Hearth.com] Traditional Hearth Modification questions](https://www.hearth.com/talk/data/attachments/250/250534-e609564b0e16007c661be8611a2421d1.jpg?hash=zI0sq0guA1)
