Trouble Shooting Help
cricker
4
Boston North
I have a Lopi Pioneer Bay Pellet insert. When I turn it on the auger will not come on. This all happened when I took it apart to clean it at the end of the season this spring. I know the board is sensitive, could I have damaged it during disassembly? Your help is greatly appreciated!
Have you tried connecting straight 120 v to the auger motor to make sure it's good?
Well, if it ISN"T turning, it could either be a bad motor, or possibly something jammed in the auger flight. If you can disconnect the motor from the auger shaft before trying it, then you'd know for sure.
