symptoms: after I hit the power switch, the auger starts feeding like normal. the igniter ignites like normal, I have fire like normal, the blower that blows air over the heat tubes kicks in like normal --- then a couple minutes later, the auger stops, the fire goes out and it flashes on #3 3 times.   I put a jumper across the two brown wires, same thing as before. I've cleaned out the burn chamber and burn pot and the chimney is clean and clear.
after doing a little research, I figured I need either a high limit switch or a low limit switch. there lies my question, which one? is there a way to test the voltages out of these sensors? what should they be putting out?
Thanks in advance
Dave
Thanks in advance
Dave
