Hello, we had a new stove installed this year and it is AMAZING!! Clearly the stove that came with our home had seen better days... My issue now is trying to circulate enough of our wonderful wood heat from the main floor to the crawlspace as the ambient temp now makes the thermostat for the furnace redundant. ;0 )
I have the furnace fan running constantly and although it helps prevent us from melting by circulating the cooler air from downstairs, my wireless remote temp guage downstairs has me thinking that not enough heat is making its way down. I have also enlisted the help of a tower air purifier positioned beside the stove pointed in the direction of the closest return, The furnace, water softener and pump are all down there so the temp is something to be aware of. I currently have a temp alarm set to -10 on my remote device but the idea of having to crank the furnace over the ambient temp in order to heat the crawlspace is ridiculous!! ;0 (
Without any major construction (adding a return closer to the stove etc.) I am looking for ideas on how to move more heat through the return(s).
Additionally, I am looking for general ballpark temps as the max LOW before freeze for PEX piping.
*we have never had an issue with freezing in years past but it is clear now that the inefficiency of the old stove would have ensured the furnace kicked on overnight*
Some deets I am sure I will be asked for:
Open concept main floor with well positioned stove (PE Alderlea T6)
propane forced air furnace with 2 air exchange units on main floor (neither close to the stove)
wood foundation on bedrock (can stand sort of and walk in crawlspace) crawlspace is dry all year
PEX piping water lines.
thank you in advance for your time and info
