Salutations,
Signed up. Trying to digest as much information as I can in the forums. I'm a noob. I guess I've learned that the pellet stove is not quite plug and play.
Do you play with your cold air intake damper everyday, several times a day? As your outside temp drops or the wind changes directions do you play with it again? Is your stove not supposed to run optimally in the factory preset settings? Why change the blower speed to a higher level if the auger is dropping pellets at a slow speed? What exactly do clinkers look like?
Why use high silicone gasket as opposed to the factory recommended? I could go on...on and on with questions.
Cheers.
Heather
Cheers.
Heather
