Has anyone tried using Tyvek to cover their stacks? It is waterproof, yet breathes so moisture does not accumulate beneath it. Seems like a reasonable alternative to a tarp as it promotes drying.
Al, Tyvek was never meant to be a stand-alone barrier, especially on top-exposed surfaces. It is also prone to ripping/tearing when abraded against sharper objects (like a jagged edge of a split), I'd probably not use of. Its also pricy, too (especially the original Dupont brand). Most "off" brands of housewrap are basically cheaply made tarp material. They don't hold off well in the weather by themselves.Has anyone tried using Tyvek to cover their stacks? It is waterproof, yet breathes so moisture does not accumulate beneath it. Seems like a reasonable alternative to a tarp as it promotes drying.
Even the six mil black plastic from HD that I use isn't cheap. But......they have 20' wide rolls.![]()
I hope this also helps someone else who is as OCD on this as I am. Never thought I get this intense on wood.
I like this idea ,and I'm lookin at a couple of used pool covers , a 15' x 30' and a 16 × 40 oval , $20 eachBuy some 12 X 12 tarps.
Cut them in half, roll & staple (roofing nail) the edges to a 12' - 2 X 4. (or a 2 X 2 )
End up being about 5' wide.
They roll up & store easy enough & are easy on & off.
Have some weight to help keep them on & give you a solid connection for bungees down to the pallets on the ground.
If I did that now I might lay pallets on top of the stack , then put the tarps on. Better air circ.![]()
It's pouring out there as I write this. Glad I got the cover on at least two stacks. We will know if I pitched it enough pretty quick.Me neither. But it pays off in big dividends, less creosote & more heat
Just stack it so the top row is a 1/2 a bubble off, so the water runs off. LOL![]()
Good price on the used covers. Just make sure they are still waterproof. They have a way of going to chit all at once. You just reminded me I have an old pool cover. Going to cut that up and use it too.I like this idea ,and I'm lookin at a couple of used pool covers , a 15' x 30' and a 16 × 40 oval , $20 each
