I have a raised ranch with an Avalon 996 wood insert in the basement. I've used it for years setup with a stainless cleanout connected to a short section of 8x6" oval that terminated in the smoke chamber about 6" over the flue blanking plate. The rest was 11x11 terracotta chimney. I had some poor drafts getting it going on warmer days but the stove burnt hot. Like hot enough where you couldn't stand too close and would keep the home cozy with the thermostats at 60. If I shut the basement door the heat would be intolerable quickly.
Last fall I decided I wanted to line the chimney. I installed an insulated 6" liner (25'). It drafts great, no smoke in the house at all, but the stove doesn't seem to be throwing off the heat I remember it used to. I have a new provider of wood and had 2 cords delivered with a variety of hardwoods. I just split 3 different species and find moisture content ~20% with my General pin meter. I also mix in a little 3 year old seasoned hemlock and pallet wood.
I'm wondering if the new liner in an older stove is allowing issues with it to be more apparent. Perhaps the better draft of a 6" insulated liner is magnifying a tired door/glass seal pulling too much heat up out of the house??
What should I look for??
