When does it make sense to upgrade a boiler that is still working well?
My boiler is way oversized. It was oversized when I inherited the house, and I've worked on this house to the point it's no longer the same house. I've upgraded windows and insulation, air sealed and then air sealed some more. I'm currently foaming the basement walls as I feel that's where a good portion of my heat exits. The boiler is used to heat water and heat the house.
Any ideas on when or if it should be upgraded? I don't burn as much at the house as I used to since I switched the oil burner out for gas. The boiler is used to heat water in addition to the house.
