I've noticed that the exhaust gas from my pellet stove is pretty hot (duh)... anyway the other day I noted that the snow and ice on a metal frame (equipment base) that was beside the exhaust was warm, despite it being -2f. This was from the exhaust blowing on or just near it for a couple hours while I brought my shop from 50f to 65f.
This struck me as a potential heat source.
I was wondering if anyone has built a heat sink or copper coil that the exhaust would blow over...I was thinking that one might circulate water/anti-freeze solution through the coil (heat sink) and then into a receptacle in the house (or in my case shop) that could store that heat and then use it when the stove was off.. so use the heat from the stove when needed and heat from the tank when the stove is off....
I've got a 250 gal plastic tank (in a tote)..I was thinking if I could drive the temp up to 100-110 f it would be easy to create a simple pump/radiator system in the shop that draws from that heat.. this would create a much longer time between heat cycles for the stove....
just wondering who has built one...I'm gonna try!
edit... I KNOW it would have to be seperate from the exhaust... say a coil in a box that the exhaust blew through... my exhaust is straight out with a 45 degree downspout.. total length about 48"
