Ussc 6039
janicevet
17
Ohio
I am nervous to start messing with the settings other than the auto settings. I think I have a lazy flame but am new to this. I have ash building up on the back firebrick. My model only has the A BC buttons. The manual is not clear on what these do. Any help would be appreciated. I just cleaned it well two days ago.
How old is the stove? Did you clean the internal exhaust pathways and exhaust venting?
I use a dryer vent brush and set up an old chunk of hose on an adapter for the Elena but stoves do tend to have different exhaust pathways inside. For the exhaust venting for my stove, it works on hours (1,000). It works out to about every ton. Not sure how much fly ash gets exhausted on the US stoves. How much have you burned?
Edit: What vent configuration do you have? up & out, out & up, straight out? Do you have an outside air kit (OAK) hooked up?
Should clean out the exhaust then when you change settings your getting a better idea of the changes...
As to the settings, make a record of the original starting point and allow for 1/2 hour for any noticeable changes in function of the stove... you can always go back to the starting point. Check record of what exact changes you make, every time you make them.
Your manual should have basic info on settings. Common questions are found here: https://www.usstove.com/index.php?route=information/page&post=166 They have videos on the 6041 which is the most recent version of the 6039 that may be of help: https://www.usstove.com/index.php?route=information/page&post=111
Then there is always the search of the forum ... info should make your eyes cross ==c (box top right).
Reactions: FirepotPete
Thank you!! Cleaned the exhaust today and the flame is much lower and seems better. Time will tell.
Reactions: Lake Girl
Start studying up that manual and read through the posts on the forum and you should have it fine tuned in no time!
Dang, we need to make a "clean out video" on the 6039 for everyone. Been quite a few this year asking about them. Ill see if i can find the response from firepotpete that he wrote up last week, then post a link.
That would be really helpful for a newbie like me. The manual is not real great and explaining it all.
once it warms up a little and i got time to shut stove down and do a thorough cleanout, ill go-pro it for ya!
Mine does tunnel the pellets, but it doesn't bridge them (by this i mean, it continues to feed) like a hopper should. It doesn't stop feeding and go out.
Something that helps me tremendously is the fact that ive got a 4 bag hopper for mine. had it custom made at Local fab shop. Cost me 100 bucks and looks like OEM and functions like OEM. Its a god sent for cold weather. When im running HR1, i fill it up on Friday evening and check it on Sunday evening. lol
Reactions: Shane1
Yes mine bridges
That is usually from the pellets. My stove only has bridged so far with Trebio pellets. I mostly use Spruce Pointe, Lacrete, Okanagan platinum
I've never had those problems, but, I only use, Golden, Corn, Kernels. ;)
Reactions: mustangwagz
