Ventis Double Wall Telescoping Section Troubles
oldpineyfeller
6
Idaho
Just got all my stovepipe in for this new stove. Went with Ventis double wall. Overall the pieces look very nice, but I’m having a problem:
The two pieces that make up the 40”-68” telescoping section won’t slide together. The outer walls slide one over the other nicely, but the inner walls appear to be the exact same diameter. They start because the lower inner wall is flared at the end, but it can’t slide past the flare. Tried tapping with a 2x6 and all it did was begin to swage down the upper inner wall as it tried to slide down into the lower one. Definite no-go.
Anyone experienced this before? Am I crazy for thinking a telescoping section should telescope?
That's surprising. I'm glad they are correcting this for you.
Received the new telescoping pipes today and they have the same problem as the old pipes.
Turns out the inner pipes were in the wrong outers. I cut them out, switched them, and welded them back in. Now it goes together.
Here are three videos I made to send to Copperfield:
Vid 1 - The problem
Vid 2 - The fix
Vid 3 - Success
Hopefully Copperfield sends a working telescoping assembly once they get a new batch in.
That is unusual. Sure looks like a manufacturing whoops.
Well it’s been radio silence from Copperfield since I contacted them about the second faulty pipe. Kind of disappointed there.
On the bright side, I was able to install the repaired telescoping section and it is working well.
The project was changing everything from 6” to 8” for a Blazeking. The 24 foot vaulted ceiling made the task challenging, but it all came together with the help of some scaffolding.
