Hi everyone. When I had my 1986 Defiant Encore installed four years ago, the installer said the top was loose/broken because even though the top center screw was in place, you could lift it up from the back about a quarter inch. The screw is stuck and stripped, so we couldn't look at the underside. He caulked it in with high-temperature (2000-degree) sealant. The stove burned well, but the sealant has since chipped away. I just re-caulked everything, but now that I am done with that, I'm wondering if he has steered me wrong and I've continued down the wrong path. Are there fiberglass seals on the underside, does it just sit on there dry, or some other thing? I can't find anything on the internet about this, even in the parts diagrams. It appears there are bolt holes on the underside of the lip on the left and right, but maybe that's for the warming shelves, which I do not have. Any guidance on this would be massively appreciated. I can try to get pictures, but you wouldn't really be able to see anything. Thanks a million.
Brian
Brian
