I have a 10 year old Encore. While replacing the catalytic converter, realized the Refractory Assembly was damaged and needed replacement. This required removal of the right air plate. Everything is back together and convertor is working as expected. When the stove is cold the air control damper positions fine. When I start a fire and the stove is heating the air control damper will run closed. I looked on the VC site for adjustment procedure, but found none.
Any suggestions?
Any suggestions?
