Our fireplace and chimney guys came and put in a new chimney liner and double wall stove pipe. I've used this stove for 20 years and it easily kept the living room in the 80s if I wanted it that hot. Kept the upstairs reasonably warm, too. After the repairs, the stove barely gets the room up to 70 degrees and even with that the oil furnace is kicking on. I can actually touch the griddle briefly without getting burned. I had the guy come back out and he said that the work they did improved the draft and it's working more efficiently and that's just how it is. I'm in a bit of a state because I spent money on repairs only to have a stove that no longer heats the house, though technically it is safer, meets code and has incredible draft. I'm trying to figure out what to do to get my wood stove functioning again.
The old stove pipe was single wall and had two 90 degree elbows. The new stove pipe is double wall and has a 45 degree and a 90 degree. The fireplace guy suggested replacing the double wall with single wall to get some heat from the stove pipe and adding back the 90 degree elbow to decrease the draft. Problem is that the pipe doesn't really have enough clearance from the ceiling to meet current code, which is why they put in double wall. They won't do something that doesn't meet code so if I want it back the way it used to be I have to do it myself. I did try to put new single wall stove pipe back, but I can't get the elbow to fit over the crimped piece sticking out of the chimney.
I am open to suggestions.
Anna
Anna
