Vermont Castings Vigilant l- A friend of a friend has one for 500.00 and says its like new. Can anyo
PHARO
10
midwest
Im looking to heat 1300 sq ft and am placing what ever stove I get on my hearth and running a new pipe. Currently there is a POS fireplace insert in my house. Is this a good deal and is this stove efficient or should I hold out for a better one. ANy infor would be great
The original Vigilant sold for less than that new. That does not mean the stove is not worth the money......
BUT, there are a number of models of this stove. Most do not easily fit into a fireplace. You'd need a tall opening to accept it, plus a good hearth. Then you have to deal with clearances, the chimney, etc. etc.
https://www.hearth.com/econtent/index.php/wiki/Vermont_Castings_Older_Stove_Models/
Has some spec sheet and a manual.
Better to do your research now......than later....or too late.
If it is truly in good shape, that is a fair price. I bought a used VC Defiant in 1988 for $400. and thought I got a good deal at the time. As to whether it is sufficient to heat your home, that depends on the amount of insulation, and airtightness of your home.
I haver been using a VC Vigilant for 8 years now . It came with the house and has glass doors. "The back part sits just inside a fireplace. I t rreally does throw a lot of heat once it gets going.
It's a good old heater. If the stove is truly "like new", inside and out (and pay attention to inside), then I'd offer $400.
If its truely one of the first vigilants, check out the fireback of the stove. The originals had a one piece fireback that they no longer offer. If its cracked, it needs to be replaced with a two piece fireback kit, which could run you a couple hundred bucks. You have to figure this stove could be 25 to 30 years old, and who knows how many people have burned this stove.
