I thought I would post about the new Vogelzang Ponderosa, since I have a Vogelzang Performer.
I really like my Performer Wood Stove. For the price its a heck of a deal. I got it onsale last fall at Menards. I have looked at other stoves on displays and my stove is very well built.
So anyways the New Designed Ponderosa is rated at a 87% Efficiency as tested by Omni Test Labs.
That is dang high for a non-cat stove.
The Ponderosa has a second control lever you dont see on other non-cat tube type stoves. Its called the High Burn Control but I dont know what its actually doing.
The firebox is 18.5" x 26" and the stove has 6 burn tubes in it, maybe the extra tubes make it extra efficient. Plus maybe since it has so many tubes that may point to the extra control lever as being some type of secondary air control.
But I thought I would shed some light on this stove as the 87% efficiency rating is one of the highest I have seen in a non-cat stove. Even higher than the hybrids. I am sure Omni test labs use the same test protocol as on other stoves.
I will post this pic as what is the thing sticking up at the bottom of the door frame inside , that looks to be something different as maybe in air flow or something.
EDIT: FOUND OUT TODAY THE STOVE IS RATED 81% EFFICIENCY NOT 87% STILL HIGH NUMBER FOR NON-CAT STOVE
![[Hearth.com] Vogelzang Ponderosa [Hearth.com] Vogelzang Ponderosa](/talk/proxy.php?image=http%3A%2F%2Fwww.northerntool.com%2Fimages%2Fproduct%2Fadditional_images%2F28106_1_lg.jpg&hash=4e03fa5085e91cc4451a225504516fed)
