There was an interesting evaluation done by the Journal of LIght Construction on air sealing materials including caulks, tapes, etc. One finding that surprised me was that Liquid Nails did a really good job of sealing between different boards and a wiring penetrations. I can attest to how well liquid nails works after tearing out our basement walls for remodeling. The stuff is tough!
That said, there are many good caulks for air sealing out there. I think that main thing to keep in mind is that they do not work well in larger gaps unless you use foam backer.
The JLC article is here (I hope): http://tinyurl.com/ova3mwf
Ok, so after days of racking my brain and reading as much as I could, I am being paralyzed by too much analysis. I'm pulling the trigger on this approach. Quick context - we are in climate zone 6. The wall I'm working on is an exterior wall, fully exposed to the outside but is part of a walk-out basement (this is the wall on the walk out side). Objective is to achieve better thermal efficiency in the wall.
1. Remove existing vapor barrier, drwall and existing insulation (standard fiberglass, best I can tell)
2. Seal all framing edges (where framing meets sheathing on exterior), framing pentrations and top and bottom plates - use DynaFlex 230 for most sealing. Will have spray foam on hand for larger gaps and holes
3. Install Roxul ComfortBatts
4. New drywall - may even seal new drywall to framing if time allows
Hope to start work within a week or two. Will let you know how it goes!
Suggestions, comments or concerns are always welcome so speak up
There may be no sheathing outside the foam. Sheathing is only needed for attachment of siding and a water/wind barrier, and for prevention of racking. Siding can be attached to the studs, or better yet furring strips attached to the studs, to create a drainage plane. Foam may serve as water/wind barrier though house wrap may be installed under the siding or furring strips. Using foam this way, wood sheathing is primarily needed only in the corners to prevent racking.Interesting part of this was that I discovered that there is an inch of foam board on the outside (you can see the blue boards in the first two pics). I wasn't expecting any insulation on the outside as this home was built in the mid-late 70s. I'm guessing they resided at some point and that was when it was added. - foam was right up against the studs so I assume there is sheathing on top of that, on the exterior.
Edit: foam installed this way helps prevent thermal bridging through the studs.
