Wall Thimble Against Insulation.....
ckdeuce
264
Western, PA
I installed our new Mansfield yesterday. Wooo!! I used a wall thimble kit, and did not see anywhere in the directions on what to do with the insulation in the wall. I just cut the hole, removed enough insulation (blown-in celuose) and put the thimble together. Is it ok that the insulation will eventually settle and rest against the outside of the wall thimble? I imagine it is safe..... The thimble gives the needed 2" clearence for the class A pipe that goes through the wall... Is that enough?
Should I have boxed in the thimble so that the insulation will never come in contact with it?
Anyone else just let the insulation rest against the thimble?
Thanks
Chris
  • [Hearth.com] Wall Thimble Against Insulation.....
Yes, my insulation is in contact with my thimble. I have fiberglass insulation which I was not able to get to burn with a blow torch. I think cellulose is also very safe but didn't read this entire web page. (broken link removed)
I believe the air gap in the thimble is supposed to be the required minimum distance to combustibles. Niether insulation would be considered a combustible.
Mike -
