Hi all! Started my install and got the wall thimble in place.
Had some questions about using sealants at certain areas of the thimble.
First - the spot where the thimble passes through the exterior siding/sheathing. Looks like I can seal gap between sheathing and metal thimble from the inside. Is this necessary? It is not called for in instructions... but seems like a good way to keep out weather - moisture - creepy crawlers - yeti, etc.
Second, where the class A pipe passes into the thimble flashing on the exterior of the house. This is not a very large gap... just wondering if it is standard practice to use sealant here to keep any water, etc. out of the thimble/wall assembly. I have a few tubes of RTV if needed.
I am not sure if the pass thru gap in the tee is supposed to stay unsealed for venting?
Last, I imagine it is perfectly safe to stuff some roxul mineral wool insulation into the frame for the thimble? If the outer thimble can contact wood shims to secure, makes sense that insulation is good, right?
Thank you!
Pics with red arrows to illustrate:
![[Hearth.com] Wall thimble - sealant necessary? [Hearth.com] Wall thimble - sealant necessary?](https://www.hearth.com/talk/data/attachments/217/217918-5ca565cbe82c40d2fb42d7693b8b8dad.jpg?hash=QoLuF5PwL6)
Thank you!
![[Hearth.com] Wall thimble - sealant necessary? [Hearth.com] Wall thimble - sealant necessary?](https://www.hearth.com/talk/data/attachments/217/217915-79c953c5f6cac9bf6eb67a6671110a73.jpg?hash=YqCZY5g_k6)
![[Hearth.com] Wall thimble - sealant necessary? [Hearth.com] Wall thimble - sealant necessary?](https://www.hearth.com/talk/data/attachments/217/217916-4585ddb3dc319af0f32818d8f10adccb.jpg?hash=q6BMlLOHlk)
![[Hearth.com] Wall thimble - sealant necessary? [Hearth.com] Wall thimble - sealant necessary?](https://www.hearth.com/talk/data/attachments/217/217917-210bbd683c9cca7edd4bbc585558b8d4.jpg?hash=sRbgzTVvO0)
