Water temp. App
Jesse-M
191
Columbia City, IN
I would love to be able to check my water temperature from my iPhone.......
At home or away...... Sure would be awesome.
I have never used one but controlbyweb.com has some interesting stuff. I think the x300 was the on I was considering.
gg
Cool..... I'll check those out........ Anyone use a web cam for this?
Jesse there is a device for an iphone called igrill I think if you hook this up it sends the temps back to your iphone
I used control by web.
i didn't care about seeing it from offsite.. so i went with the cheaper module.
Look up a thread i started called "internet enabled" shows what I bought and whatnot.
Pretty easy to hook up. The X300 is more money, but can be accessed offsite and will data log.
JP
I've been working on that myself. Haven't put anything together yet. I did see this.
(broken link removed to http://www.smarthome.com/iphone_apps.html)
I don't monitor my wood heat remotely since it is not water based. I did however setup an IP camera on my new gas furnace that was acting up. I have an android app that I can view the RTSP streams directly but I also hosted the camera on Click2Stream so I can view it from anywhere on the internet through any browser.
I work in IT and have installed many IP cams for security and for process monitoring. I also use environment monitoring for my data centres and they email/text me.
There are cameras with dry contacts that you could connect a basic mercury bulb thermostat to. The camera can be configured to send emails on contact closure.
I saw a web cam in the last Source flyer that sounded like it could be used on a wireless network, and accessed via internet. Planning to check that out - I could mount one with a view of one of my temp guage panels, and LED indicator light that comes on when back up heat is called for. Any more hints for the semi-ignorant home owner on this stuff? This one was somewhere between $100-200. Is that the going rate?
a buddy uses one that's supposed to be easy. called a "drop cam"
I saw this in a store yesterday when I was out:
(broken link removed to http://www.dlink.com/ca/en/home-solutions/view/network-cameras/dcs-930l-wireless-n-network-camera)
It was in the $60-70 range. I almost got it on the spot but held off until I did a bit of searching on it - reviews I just found are mixed though. Anyone with experience? I'm thinking it's worth a try.
