"Forged steel half coupling" is a term of art for a fitting that is manufactured to be like half a coupling.So, a plain black coupling cut half will work? I have two tanks that I am bringing to a welding shop to do my storage
tanks and we were not sure what type of fitting to use.
If you're going into the side I'd say use 1.5" so you'll have room for a double-tapped bush that you can use to install a dip tube and a riser to get closer to the ends of the tank (for both ports assuming you're going vertical, or just the return if you're going horizontal).What size fittings do you use? I was planning on just using 1 inch, since I am just running 1 inch pex to them.
I also have to cut the holes in the used propane tanks before I take them to the shop. My plan is to fill the tanks with water
then use a hole saw to cut in the proper size hole. Will a hole saw work? I know the metal is about 1/4-3/8 inch thick.
For short tanks all you need is just one port on the ends of the tank at the apex of each dome, assuming you have room to go vertical. Then you won't ever need dip tubes and 1" would be big enough. (May want to add a 3/4" fitting for temperature well near top of one or both tanks.)Right now I am going ahead with 2 120 gallon propane tanks tied together or 2 250 gallon tanks if I can find one or two in the next
few days. I really want to get some storage soon. I am planning on just putting 4 taps in each tank, 2 near the top and 2 near the bottom. I had not planned on the dip tubes, but I think I will put the bigger fittings on just in case I change my plans.
