Hi all, and what are the tubes at the top with the holes in them actually doing? Can you give details...
Thanks
Thanks
And the link is at?
Wow thank you guys, I am now feeling that I am under firing my insert, once going, I put two skinnier splits on bottom straight in, then one regular or much bigger split crosswise so u can now see a nice flame in the glass. Today I put 3 regular splits on top of the 2 skinnier ones, after a few minutes I played with the air intake, upon closing fully I started noticing flames coming from a few holes (4 pipes tota) scattered through the holes, no flames coming from front 2 pipes. Doing this for the first time I started hearing a few noises in the insert, I'm thinking normal noises because I'm running her hot. But how hot is too hot? Like I said, I put in 2 small splits to lay a pad for the 3 I put in on top for the first time. Thanks for all input. And u guys seem very knowledgea .supply super heated ( when correctly configured) combustion air to mix with volatile gases rising off burning wood, pyrotecnics at the top of fire box are the result. Less emmisions up flue means less creosote. This also improves the over all efficiency of the unit. Progress Hy-bred has both secondary burn tubes as well as catalytic combuster so that is just about as far as the envelope can be pushed with out getting insane like our automotive devices.
Maybe someone who has a Monty will chime in as to where you can put a surface thermo on it...But how hot is too hot?
It's that big youtube window in my post....??
Only place to put it is on the glass. The glass area is bigger then the box. How hot can glass get before something bad happens? ThanksIf ya got a guage on the stove try not to go over 800ya need to start closing down the primary air when ya git to the 400-500
marks little bit at a time. do not know your stove but mine will cruise at the 600-700
for awhile with just the secondaries dancing
Well running Mozilla Firefox and a no show will have to open up IE..LOL
Wet wood is a good indicator of no secondaries.
Great, thank you, I have been babying it, 2 small splits and then a good split on top at a time. I loaded it on Wednesday and I'm seeing better results, clean glass, red coals 24 hr later, warmer room. I have a drafty old house and no cut off plate like people are saying u need, so I keep experimenting, I only burn dry wood but I think I'm always under firing . How much wood is proper but not too much, thank youHi Ram Montpelier was designed for max glass view, so no good spot for thermometer... some people put it on the door frame corners, but doesn't give a good indication, at 200 degrees on the thermometer, the fire is going good at that point. So with the Montpelier, visual is best. Good active flame, with good wood, about 1/3 to 1/2 air shutter open will give good results. I know the firebox is tapered, ideally 16-18 in back with 20 in pieces towards the front. For max burn time, more wood in firebox gives more, cleaner heat out. Oh yeah, if blower isn't coming on within 45min to 1 hr, clear ashes off front ceramic area. If your blower is wired for automatic (it should be) the snap disc is up front and center underneath. Hope this helps.
Good questionHi all, and what are the tubes at the top with the holes in them actually doing? Can you give details...
Thanks
I load up for max burn, my wood never seems too dry, but I've heard from other folks on here sometimes you can overfire a stove with a full load experimenting is always your best plan and see what works. Good luck.
