What happens after El Nino winter?
Yup, but your cat was spot on this year.Forecasting a year ahead is Old Farmer's Almanac brand of BS.
nino typically brings in high moisture, this year different as it has moved into the northwest as well as the south.. nina will dry out again. think winter was warm, this summer will push records everywhere as la nina is forecast( there's that word again) to grow rapidly.my go to J Bastardi saying 16 hurricane season gonna be a bad one. everything you need to know. la nina-el nino (broken link removed to http://www.wrcc.dri.edu/enso/ensofaq.html)All long range forecasts expected the PNW to be drier with el Nino dumping the rains south in CA. Well, it's March now and we have set record rainfalls for every month since October. Wettest winter I have ever experienced. So much for long range forecasting.
here is the skill grades for the two forecast systems, via r. maue twitterThe US finally is about to catch up with the European forecasting systems (that got Sandy right) with bringing online two new Cray supercomputers. Let's just hope that politics don't get in the way.
http://cliffmass.blogspot.com/2016/02/the-national-weather-services-new.html
You are absolutely correct, I do believe in climate change and I believe that whole area is turning into more of an arid climate because of it. Wild land fires are not something to laugh at, they create there own micro climates and alter weather patterns, very powerful stuff.short term forescast for another problem?
Joe Bastardi @BigJoeBastardi 25m25 minutes ago Pennsylvania, USA
California above normal precip likely to continue into May.. Implications good, then bad, as it may mean big wildfire season, extra fuel
