I plan to line my 100 year old brick chimney with 6" SS flexible liner. I have to knock out part of the chimney to insert a T. There is no cleanout at the bottom of the chimney, only a hole where the old fuel furnace used to vent in the basement. Can I use that hole as the cleanout, and leave the bottom of the T open? Woodstove will beused (not an insert).
! the tee MUST be plugged. im not sure what you are talking about here. does the chimney go down into the basement? and you want to vent a stove through it on the first floor?
