What is the best air filter to get?
Svalen24
5
massachusetts
I am planning to install a wood stove in my basement.
My wife is pregnant and will not be going in the basement,
I will be going down there to load the stove.
I have a forced hot air system with a zone upstairs and a zone in
The basement with a hepa filter.
What is the method to filter my air? Is it important
To find a filter that deals with Carbon Monoxide?
I plan to install air quality monitors in the basement and upstairs
As well.
Do you think I could get any spikes in carbon monoxide
Or anything else upstairs where my wife would be?
I plan to keep a basement window cracked open all winter.
Any insights are helpful.
Thanks
As well.
Thanks
No air filter removes carbon monoxide. Install and operate your stove properly and its not a worry. But as always you should have high quality CO monitors and alarms if you have any fuel burning appliances
FWIW. Over the last 10 yrs. I don't think our CO monitor has ever registered any CO.
I had a marginal chimney reverse draft at the end of a burn once. The CO detector notified us.
Installing in a basement can have issues. If your walls aren’t insulated, you can lose 30% of your heat through the walls. It may cost you more to install a woodstove and try to heat in that circumstance.
What was said above a properly installed stove and you will have no issue.. Keeping a window open is sort of counter productive.
My basement walls are insulated
That's good for keeping the heat in the building, but is not too relevant for the potential of draft reversal due to negative pressure. This site has some excellent articles on what causes negative pressure in the lowest level of a house.
Do you have dry firewood set aside? Most sellers claim their firewood is “seasoned”. Seasoned does not mean dry. Some species of wood can take over 2 years to dry.
Also, how tall will your chimney be? Too short of a chimney can make too little draft, while too tall can create too much. This can make a stove hard to control.
Oak usually takes 2+. Split a piece and test the center with the grain.
