Hello All,
I finally received my Hargrove propane gas logs and I've decided to do the work myself and run black pipe from the side of my house to my fireplace.
My run will be a total of 40'. From the outside tank, it will be 30' to the top of my fireplace enclosure in the attic and 10' down to the burner. I plan on putting a T at the end of that 30' run above the fireplace in case I want to install a run to my outside fireplace at a later date. That run would be about 30'.
Since I only want to do this one time, I was thinking of using 3/4" pipe for the entire run. Is that the correct size to use or is it overkill?
Thanks,
John
Thanks,
John
