Id check the load rating on the tires of any 1/2 ton truck before i would overload it. Even if you dint blow a tire you might be doing damage that will show up later. weakening the springs,tearing belts in tires,premature bearing failure ect2200 pallet 2006 f150, no issues
Dump trailers are nice,my son has one that will handle 5 tons in one trip plus a ton in the truck bed. Just about any 3/4 ton truck can pull it.Too big for half ton trucks to pull a trailer that big, the brakes are too small among other things
My truck has a 12000 Lb tow rating some 3/4 tons have up to 160000. Not sure if you can load the bed too but i dont see why not.I think this is incorrect (If you mean legally)!
I haul a ton on my "97 half ton Chevy. It doesn't bother her a bit. A little high center of gravity but if you stacked them in you'd never know their back there. Check your state laws on what licence plates you need. At least C (if you're lucky) in WI.
The biggest worry besides the fines and truck confiscation in some states is the heat build up in the tires IMHO. Once when I was young and stupid, I hauled green firewood in my old F100 to where it was down on the rubber stops. I even had 3500 of coal on it one time. It sure felt like it had power steering during the 1 1/2 hour ride down from the coal regions! THEN I FELT THE BACK TIRES
! They were hot as hell. Never did it again. Now I have an enclosed trailer rated for 3500 pounds. It weighs 1200 pounds.
Didn't notice anyone talking about trailer brakes..................... Maybe I missed it.Overloading something can get expensive in a hurry.
This summer I hauled some topsoil to my place. I was using my bosses truck, a 2000 something GMC 2500 gas job.
Got the trailer loaded down with about 9 yards. Wasn't quite full, but the girl working the counter said it was about 1200lbs a yard so I was sitting at about max weight for my trailer (12k)
I ended up blowing a tire, bending that trailer axle and breaking the hitch on the truck. (wasn't cheap to fix all that!)
Come to find out it was more around 2000lbs a yard so I had about 18,000lbs on my trailer. Counting trailer I was pulling about 21,000lbs.
Actually pulled it very well all things considered!
AMENSure your truck can PULL it ,but can you STOP it. What happens when someone pulls out in front of you and you got 1+ tons in the back of your 1/2 ton truck with the 1/2 ton tires and the 1/2 ton brakes and the 1/2 ton axle. What happens is that unlucky person(and you) gets t-boned. ANd you get fined (If your still alive)
I `ll take option 2.
Hello , home depot / lowes could you deliver 6 tons of pellets $55-79 delivery charge plus min 6 months to pay for it with special financing (everyday deal ) ummm ok no wear & tear on my truck ,no lawsuits , less of a broken back plus i save on my fuel costs ummmI `ll take option 2.
Safety? We Don't Need No Stinking Safety!
Where did all of the mother figures come from? I was enjoying all the reading about DMV and DOT violations.
Like I said earlier, my Dodge B1500 Van hauled a ton. I was smart enough to drive slowly and avoid possible fines and wrecks.
I am sure that most here will not travel at 95mph while loaded to the gills!
Bill
I could also get ran over by a busload of nuns while crossing the road tomorrow. Many "1/2 ton" trucks can haul 2000lbs without much trouble. Better yet get a trailer that can hold 5-6 tons and use that instead.
Coming home last night met up with an F350 putting a "dumper-roo" trailer. The bottom of the ball mount was maybe 2" from rubbing the ground, front tires of the truck barely touching the ground. The trailers tires were set at about 20* from being straight, the axles were bent that badly. Tires were squashed down so hard that the wheels were hitting the pavement on bumps. It was rolling out smoke from something on the trailer... wheel bearing locking up maybe.
Not sure what he was loaded with, but I do know he passed me doing 80+mph.![]()
