What is a person to do if they experience a flue fire?
Is a flue fire most likely to happen when your starting a fire,
when its the hottest, or when your gone?
Here is an article i read about causing a flue fire on purpose!
http://www.endtimesreport.com/chimney_cleaning.html
Airtight stoves and tight fitting, stainless steel, insulated stove pipe are a different matter entirely. Due to the nature of the stoves (particularly if they have an automatic draft control for temperature regulation) they WILL build up a layer of creosote in the chimney, and that creosote WILL burn. If a flue fire gets started in an airtight stove, a small glass of water thrown on the fire will flash to steam and inhibit the flue fire, BUT it may also severely damage the stove: glass doors can break, the steel or cast iron may not be able to adjust to the temperature difference and crack, etc.
Everyone with an airtight stove should have their own chimney cleaning brush and rod, and then plan on inducing a controlled chimney flue fire once a month. The use of dried potato peels or newspaper -- but absolutely no wood! -- will raise the temperature of the flue sufficiently to induce a controlled "burn" that is simply a flash of heat in the chimney. A chimney temperature gauge should be on the stovepipe about 5 feet above the stove (if possible) and when the temperature reaches about 500 degrees, all dampers should be shut down and the fire starved of fuel and oxygen. The residual oxygen in the stove will keep the fire going until the temperature reaches 550 degrees or so, the go out and rapidly cool down. The dampers may then be open to induce a flush of cool air through the pipe, so it cools down faster -- in a half hour the pipe will be just slightly warm to the touch.
