My buddy just dropped off a truck full of Maple, he didn't know what type of Maple it was so i thought I would ask. It was ez to split and it had a darker middle. Thanks to any who replies i do appreciate it, is this a good wood to burn?
I think that's silver (soft) maple, which is always good to have. Fine for daytime fires, shoulder season and for mixing with dense hardwoods during a restart when the coals got a little too low. Makes excellent kindling, too. You done good.
Soft maple. We burn quite a bit of that here and like it. It doesn't get used much for night wood but daytime is great. In addition, it makes some of the very best kindling wood and as you know, it splits very easy.
Thanks guys it was free so i didnt hesitate to say I'll take it. Do you think it will be ready by October November? My buddy still has a couple trucks worth for me. I plit some ash a couple weeks ago and split them on the large size do you think that will be ready by October or November? I was standing but dead for a couple years I did test it with the MM and it was 35% moisture.
Our stove can't handle being stuffed full with dry soft maple, but some stoves are OK doing that. If silver is all you're loading, you may want to start with only partial loads until you learn silver's nature in your heater. It can burn really hot and fast. Whether it and the fatty ash splits will be ready by October depends on how much wind and sun it gets, and on what kind of summer weather you get. But, probably will be ready.
I wood have to say in the dead of summer my wood piles gets alot more wind than they do sun. The wood gets full sun when the trees loose their leaves so for about six or seven months of the year they get full sun and the other time they get partial sun.
Wow, 35% seems high for dead standing Ash (White Ash is what I'm familiar with.) Was it semi-punky? That stuff will absorb a lot of moisture if it gets rained on. Only dead a couple of years, I wouldn't think it would be punky though...
I've found some of the dead ash I cut is around 35% and some is around 27% -28% It should be down to at least 22 or 23% by fall. So yes it will burn ok ,but would burn better at 18% Maybe bring wood inside a couple weeks in advance if you can to finish drying in the warm dry house.
Yes, I think it can be ready by this fall if you handle it right. The maple usually dries super fast and the ash will too. Key is to stack it where it gets wind. Sun will help too. Put something under it so there can be air circulation under the stack and to keep it off the ground. Do not try to stack it pretty. Stack it loosely and no more than 4' high and single rows. I would not cover the wood either until fall or early winter and then cover only the top. Good luck, and get it split ASAP.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
