- Sep 19, 2012
- 26
My husband and I had our first wood insert installed yesterday (yay!). We've been fiddling with settings here and there trying to "learn" the stove.
We had a strange thing happen yesterday which scared us a little. We had a layer of embers from our first burn and wanted to add more wood. My husband took home some scraps of kiln dried unfinished oak hardwood flooring from work and we added four pieces. Within minutes, the wood was blazing out of control - like an inferno. It was terrifying. Unsure of what had happened, we closed the damper all the way, turned the fan on high and fire died down within 7-8 minutes. We did not have a thermometer at the time, so I do not know at what temperature the stove peaked. We won't be using the flooring anymore. In fact, we got some Envi-blocks to try out instead and they seem ok.
So anyway - I just picked up an IR thermometer from Home Depot, but I'm not sure where to take the temperature. We have a Vermont Castings Montpelier flush mount insert, so we can't take the temperature of the top or sides, and on the front of the unit, there is a HUGE range of temperatures and I'm not sure which is most accurate. Here's what I have right now: I've attached a picture of the unit that I took yesterday for reference.
Middle of glass: 556F
Top of glass: 527F
Curved Trim on Top of door (Middle): 361F
Sides of Door Trim: 236F
Bottom of Door Trim: 216F
Area Just Above Door Between Fan Vents: 348F
This is with the damper fully closed and the fan on medium-low. Please let me know what you guys think. Thanks in advance
![[Hearth.com] Where do I take the temperature of a wood insert? [Hearth.com] Where do I take the temperature of a wood insert?](https://www.hearth.com/talk/data/attachments/77/77132-c9c1df0c0a67e02fa731425e3a4de40b.jpg?hash=RORFNMbiZM)
Top of glass: 527F
