Hey Folks -
Believe this is my first post, but I have done a lot of searching and reading around here, great place!
So it is odd to me anyway.
I picked up this stove late last season; it is the original Quest model. I did a thorough maintenance routine after I got it and before installing it. I also have an Advantage II-T, so am not all new to the pellet stove world. This Quest is for my wife's detached office space. The stove worked pretty well for a while, then became rather inconsistent, most notable on start up.
Sometimes pushing the start button only powers up the convection fan; the auger and combustion fan do not operate. This is after attempting to activate the auger. The auger power light will illuminate, but the auger does not turn, and the combustion fan blades do not either. When I first realized this was happening, I removed the combustion fan and cleaned it extremely well. The shaft rotated freely and all, and upon reinstallation it worked okay for a while. Then this behavior began occurring again.
Oddly, I discovered if I "nudged" the fan blades to turn, the auger would start doing it's thing, and the fan would spin up to full speed. Also, at times after pushing the start button, a period of 60 seconds or more will pass and the combustion fan will spin up on it's own, and the auger will start. This is in no way consistent behavior.
As it's getting to be that time of year, I am getting both stoves ready to go. Tonight I went to start the Quest, and again the combustion fan/auger did not turn. I decided to bypass the low limit switch and try it again. This time everything started up immediately upon plugging the stove back in. Not a surprise after reading the service manual and looking at the diagram. So it seems like the switch should be replaced.
However, I do not understand the nudging the fan blades and everything spins up thing. Kind of points to the fan motor, but if someone can explain how nudging that makes it all work that would be great.
As just about any little part of these things is kind of spendy, I'd surely appreciate some experienced input before I throw money at it.
Thanks for staying with me on this post, sorry for the length!
Rob
Rob
Installed the new exhaust motor, and cleaned the ducts, nooks, and crannies on that side while doing so. Surprisingly did not need a new gasket by the way; just lucky I guess.
