I have an Old VC Defiant late 70's model. So I have been having this dilemma that I was having trouble getting temp up past 450. Was told bad wood . Got good wood still problem exists. Told air problem not enough somewhere there was a restriction or blockage. Vac and cleaned back and every other suggestion, but still same results. Every time I attempted to burn in horizontal mode the heat would dramatically fall and not come back. By accident I turned the primary air way down, was trying to put the fire out by choking it cutting off the air supply. I noticed that the stove soared to 500 then 600. WOW !! I thought it was a fluke so I repeated this many times since. Then I got temp up to 535 and went into horizontal by closing damper and lowered the primary to almost the closed position and the stove hung there and then the heat rose to 550 and stayed there for some time. Not exactly sure how long but I know my oil burner did not turn on last night till 5:30 Am and last night was cold here coldest in maybe 15 years? When I looked at the stove at 5:30 am it was still around 400 and had some very hot almost white in color coals.
I thought that more air created faster hotter burns ? This seems the opposite ! If you were wondering I did check that I was closing the primary air supply not opening it!! Can someone explain this to me?
