fossil said:You would no longer have a listed and certified solid fuel-burning appliance. You would have a dangerous inadvisedly modified and unpredictable forge. Please evacuate your loved ones from the premises before you fire something like this up. Rick
That "sucker" is what's often called a draft inducer. While it blows, in reality it is sucking from the stove.agartner said:...and installed inline on the stove pipe was a power blower.
LLigetfa said:That "sucker" is what's often called a draft inducer. While it blows, in reality it is sucking from the stove.agartner said:...and installed inline on the stove pipe was a power blower.
What I described earlier was a combustion air blower that sucks clean cold air. I've not looked closely at all pellet stoves but I think they mostly blow air into the stove and not power vent the exhaust. I expect some do both.
Dune said:The main problem is simply the inability to meter wood as a fuel, hence leading to overfiring.
I have to assume the question is being asked in an attempt to simplify exhaust installation.
Sorry, it's just not going to happen.
firefighterjake said:Dune said:The main problem is simply the inability to meter wood as a fuel, hence leading to overfiring.
I suspect this is a large reason . . . with oil or gas a certain amount of known fuel is pumped or sent to the burn chamber where it ignites and produces a know quantity of gas, heat, etc. . . . with firewood you do not have a known quantity that will produce X, Y and Z every time it burns.
Another possible reason could be that when the power goes out with a gas or oil boiler the fuel source is no longer sent to the burn chamber and there is no ignition source . . . if a woodstove had a power blower there is no easy way to simply stop the wood from burning and there would be a danger of smoke in the building, CO, etc.
Well, that and the aforementioned forge effect . . .
That said . . . I wonder if you couldn't use a power exhaust on a pellet boiler or furnace . . . just thinking . . . not that I am saying I would do so . . . just wondering if a manufacturer could do so . . . although I suspect with such a short run required with these types of heating units it wouldn't make sense to have a powered exhaust for the expense.
Marty S said:Wood stoves were not designed to be power vented.
Power venting will
* easily over fire a wood stove
* decrease safety and longevity
* increase fuel consumption
But, that doesn't mean you can't do it.
It's just not a good idea.
You can burn nitrous oxide in your car's engine
for increased performance too.
Unless you have the know how and
a specific reason to do so,
it's not a good idea.
You can start your wood stove fires with flammable
liquids but that's not a good idea either.
Aye,
Marty
Grandma used to say, "Common sense is not so common."
