I also ask because I run a millroom and I wonder if dirty rough lumber dulls planer blades to the same degree it does chainsaw chains.???
Yes, but perhaps not as fast. That dirty lumber no doubt just has some loose dirt on it but not like hitting the ground with a saw chain. Have you ever watched anyone milling lumber? If the log has been drug or dropped in some dirt, they put a de-barker on. Not so much to remove the bark but to remove the dirt before the saw hits it.
Many years ago, when I first started using a chainsaw, I haphazardly would run the bar into the ground on a lot of cuts. Never thinking it was doing any harm, I was young and stupid.
Was always frustrated that I had dull chains. As I got older (and more educated) I soon realized my mistake. Now I never let the chain hit the dirt. (well, almost never).![]()
We all know that dirt dulls chainsaw chains but what is the science behind it? Dirt is soft, wood is much harder, why does dirt instantly make a chain dull?
I can understand why dirt dulls a chain,,,,
but to me the real mystery is how the heck does GRASS dull a mower blade??![]()
Yes, dirt will dull, and some times destroy planer blades/heads. I work in a planer mill, and am very careful to not put dirty wood through. Makes every ones life easier.I also ask because I run a millroom and I wonder if dirty rough lumber dulls planer blades to the same degree it does chainsaw chains.???
Dirty lumber well dull your planner blades at light speedI also ask because I run a millroom and I wonder if dirty rough lumber dulls planer blades to the same degree it does chainsaw chains.???
