why not burn Pellets in wood stove?
jimmieguns
219
Long Island, NY
I have the UTMOST respect for regular wood burners and all the efforts in splitting,logging,stacking and ENJOYING a nice hot toasty wood fire, be it in a free standing or wood stove insert(like mine) ..( I am one :cool:), but after learning its safe and fairly as efficient to burn pellets via a PELLETEER in the wood stove why more people don't mention or advocate it.
I am just trying to learn and try new things- not judging or looking for debate, just some advice,wisdom and tried and true info
MANY Thanks!
Reactions: St_Earl
What crack are they on? A ton of pellets produces 50% more BTUS then a cord of wood?!
Maybe the lowest BTU wood, balsa? Compared to the best pellets?
1.5 tons pellets = 1 cord of wood is generally correct.
Their little bin is interesting, though I'd make one before dropping 150$. Has maybe 30$ in materials.
yeah. in one of the youtube vids the guy made his and said the metal was $24.
he just used two pieces of angle in the bottom of the stove as "feet" and set the basket on them.
Pass on the pellets, You need a basket and the results aren't that great. Use the big pellets(envi-blocks-compressed logs). You'll have better results.
Even then, I would only consider if you had issues getting season wood. Wood burns just fine in a wood eater.
What a surprise! ==c
Mech, I doubt that is Inconel, though I'd guess it would need to be something rated for the temp. I emailed them to see.
Only time I've worked on it is on boat fuel tanks and the cost is crazy. A 4x8 sheet of 1/8" was several grand!
You can burn wood pellets in a basket and use them in your wood stove. This is a true statement. But so is the following..."You can use motor oil to deep fry donuts."
Just because it is true, it does not mean it is a good idea. The entire premise of a pellet stove is that you can control the rate at which fuel is fed into the stove, and there are certain mechanisms that give pellet stoves the ability to achieve tremendous efficieny. Most of the heat that is produced is captured within the home and this is why you can vent your stove pipe right through the wall, as opposed to a wood stove.
When you burn the pellets in a wood stove, the feed contol is extremely compromised, and therefore there is a considerable bit more heat that is lost up the chimney. So yes...you can burn pellets in a woodstove, but it will be very, very expensive to heat your house this way. I have several customers who have these pellet baskest, but very few have bought pellets from me two years in a row. The second year, either they buy a pellet stove, or they buy Envi Blocks....Either way, they are better off than using this $50 basket!
Reactions: DneprDave
great posts gang! thanks for some great replies--- !!! :)
My company buys a ton of it. ALL of our tooling for the machines is Inconel HX. Only thing that can take the heat. Have several ovens that the "doghouse" is 1/4" inconel HX as well.
Envi blocks, Bio bricks, etc..... All work well.
But some 2-3 yr old Locust. The bomb!! Cord wood for wood stoves (no disrespect for the blocks. If I didn't have the time, space, and tools, I would burn them) :)
When I found locus, It was like hitting the wood hoarders lottery. ::-)
Reactions: DexterDay
The effeciency of most wood stoves is one turd less then pellet units. You have to open and feed letting more air up the 6" plus chimney. The ash will be more because the pellets are not getting forced air. There used to be kits to convert wood stoves to pellet. An insurance nightmare.
Mmmm, motor oil donuts!;lol
Dave
Probably brought to you by China. Rotten chicken jerky, wheat gluten to kill your pets and chemical laced formula for the babies. No wonder AES stoves had problems, Oh the window pellet stove to turn your kitchen into a smoker.
