I had a plumber solder all my lines from the Tarm boiler to the house(I have sold but am working with the new owner on it) and in the process the lumber got excess solder in the system and it caused my circ pump to fail small balls of solder stuck in the vanes/fins on Grundfos. The new owner did some trouble shooting and we later determined the problem with the ump. However, in the process a couple valves were messed with and I am trying to figure out how they have to be set to allow for the wood boiler to circulate into the oil boiler, There is a hose bib on both the supply and return line in the house and when they are connected with a common hose the wood boiler circulates without a problem. The question is why the wood boiler will not feed into the oil boiler. The picture shows the two valves and direction of flow. In the picture the FROM arrow is coming off a Tee the flows to the top of the oil boiler. In actuality I think this is where the mixing happens. The system worked for 3 weeks without problem, so the piping has been in place for 8 years. I used the Tarm for 5 years prior to selling the house. I relocated it closer to the house as it was in a detached garage that was not part of the house sale. The Tarm is now 20 feet from the house in it own shed. BTW I live in remote Alaska and there are no boiler shops in town. If I had access to a boiler man I would have had them come over.
![[Hearth.com] wood boiler wont circulate with oil boiler [Hearth.com] wood boiler wont circulate with oil boiler](https://www.hearth.com/talk/data/attachments/148/148461-29879cf568e4b8ce4f1610c14d2f39e7.jpg?hash=Eg0CXMoTbG)
Thanks.
Jon
Thanks.
Jon
