I'm looking to fix some smoke issues with an existing wood burning fireplace by adding fresh air intake. I feel like this topic has been brought up alot of times but didn't seem to get a solid answer. Part of it be with inserts and or wood stoves in the mix. The previous home owner abated this issue by adding an insert. We would like the option to have the doors open and it burns poorly with the doors closed. Without a window or door open the fireplace doesn't draft and smoke comes into the house. It takes about 2-3 inches before it will suck air up the chimney. As for the air pressure in the house I tested with the furnace, water heater and dryer all off. So the air intake in the utility room might not be enough for the fireplace which is fine. I don't really want to add more fresh air make up to the utility room as all that cold air would come through the house when the fireplace is on. If windows and doors open fix the fireplace draft issue I should be able to conclude adding a fresh air intake in the fire box should fix this and keep cold air from coming in the house? I'm having a hard time trying to contractors to agree to do this which seems weird.
