wood insert for tempco zc fireplace
Yes it should be. I don't have the firebox dimensions for this unit, but maybe the Avalon Rainier would fit?
I have looked at the lopi and napoleon and some dealers told me they would have no problem installing the insert and some dealers told me they would not install the wood insert. I am very confused at this time and since temco is no longer in business, I can't call them and ask them. I understand they were bought out by majestic and I can't located their phone number. Thank you for the advice
It will depend on the stove specs. The Avalon Rainier and the Lopi Revere list Tempco as an acceptable ZC mfg.. The Napoleon 102 requires that the factory built fireplace must be listed per UL 127 or ULC S610, which I think covers this unit, but look for the UL label on the Tempco to confirm.
Check out the Regency I2400 (or larger if it will fit). I think they list Temco as an acceptable zc fireplace. I have one and like it very much.
I was wondering if anyone has a temco fireplace(tfc-42-4) and they were able to put in a wood buring insert (which insert were they able to use). Also, I was told that since I have lower louvers and that the fireplace doesn't sit directly on the hearth that it would create a stability issue with the insert and was also told you can't cover the louvers. I was wondering if I should take a picture of the fireplace?
You can create a base for the insert to sit on using non-combustible materials. Some here have made a base out of 4" cement half blocks or a bed of bricks with a sheet of metal or cement board on top of them. Pavers should work too.
I've seen some inserts with stabilizing legs in front that prop it up on the surface of the hearth also
check out the picture in my avatar. they sell leg pegs for support you can then brick under the stove to make it look better. Make sure you get a fan with the insert it helps with the smaller boxes to move the heat.
md
I would like to thank everyone who tried to help me with my dilemna, but I was able to find the information about the insert on line:
WARNING: THIS FIREPLACE IS NOT INTENDED TO
BE USED WITH ANY COMPONENTS OTHER THAN
THOSE SPECIFIED IN THIS MANUAL (i.e.FIREPLACE
INSERTS, BLOWERS, GLASS DOOR EXTENSIONS,
HEAT CIRCULATORS). USE OF THESE ITEMS
COULD RESULT IN A SERIOUS FIRE HAZARD
basically the only way of overcoming this dilemna is to replace the existing fireplace. I don't think there is anything else I can do to overcome my situation.
thanks again for the help
