Is it best to let a load of wood burn down to coals and then refill the whole firebox or to always have pieces in different stages of combustion....which means opening the door often.....I have a small firebox to boot!
clearblue16 said:Is it best to let a load of wood burn down to coals and then refill the whole firebox or to always have pieces in different stages of combustion....which means opening the door often.....I have a small firebox to boot!
Yowsa! Could you elaborate on this? That is, how does adding wood in the middle of a fire "disrupt the stochiometric balance"? What happens if the stochiometric balance is disrupted? What is the stochiometric balance?CZARCAR said:epa stove with overhead 2ndary air tubes is supposed to be filled & burnt down to coals per j gulland & my sense which sez if u add wood midstage u disrupt the stochiometric balance
jammed woodstove [epa] gets fired to point where the pile is heated & offgassing, then the primary air is closed & secondary,preheated air blows over the fire & the little jets burn the gas so pretty to watch. after the jets quit flaming the overhead air's density is cooler than coalbed so air will dive down to coalbed & though coals dont need much air & may be a relative heatloss from excess air, it helps shrink the coals for next burn. upon refill the coals are raked to the front so that jammed load gets offgassing from the front= whole load offgassing may result in inadequate combustion air...i thinx
ControlFreak said:Yowsa! Could you elaborate on this? That is, how does adding wood in the middle of a fire "disrupt the stochiometric balance"? What happens if the stochiometric balance is disrupted? What is the stochiometric balance?CZARCAR said:epa stove with overhead 2ndary air tubes is supposed to be filled & burnt down to coals per j gulland & my sense which sez if u add wood midstage u disrupt the stochiometric balance
Thanks,
Dan
CZARCAR said:come to maine & test your procedureHighbeam said:I (almost) never add less than three new splits of wood. If you can't put three splits on the fire then you either didn't let the previous load burn down enough or you don't really need to be burning. During most of the heating season I will burn full loads and wait for each load to burn down. The glide time between when the firewood is reduced to coals and when you can't restart a fire is determined by outside temp and heat demand.
ControlFreak said:What happens if the stochiometric balance is disrupted? What is the stochiometric balance?
CZARCAR said:look up stochiometryControlFreak said:Yowsa! Could you elaborate on this? That is, how does adding wood in the middle of a fire "disrupt the stochiometric balance"? What happens if the stochiometric balance is disrupted? What is the stochiometric balance?CZARCAR said:epa stove with overhead 2ndary air tubes is supposed to be filled & burnt down to coals per j gulland & my sense which sez if u add wood midstage u disrupt the stochiometric balance
Thanks,
Dan
when wood is added to fire the wood introduces water & disturbs the stk
ideally= THE LOAD IS OFFGASSING & THE OVERHEAD AIRFEED,PREHEATED AIR, EFFECTS A GASSIFICATIONALIKE BURN,eh? ideally at this point 99 out of 100 overhead airholes would be flaring & that last non-flamer would insure that adequate air is present 4 combustion
CZARCAR said:when overhead tubes are flaming they provide no extra O2 for burning the wood load underneath.
CZARCAR said:study air buoyancy & density of cold vs hot air= youre WRONG!Jags said:CZARCAR said:when overhead tubes are flaming they provide no extra O2 for burning the wood load underneath.
The overhead tubes have only a small part in providing oxygen for the wood load underneath. The primary air is exactly that "PRIMARY" air. This can be adjusted to render the rest of the argument moot.
CZARCAR said:=great sounds like u know your stove.
CZARCAR said:IROYAL is top loader? how do secondaries flame?Jags said:CZARCAR said:=great sounds like u know your stove.
If I don't by now I should trade it in for a different one. %-P
CZARCAR said:so the burn tubes keep an active flame at the tube outlets during & after partial reloadJags said:CZARCAR said:IROYAL is top loader? how do secondaries flame?Jags said:CZARCAR said:=great sounds like u know your stove.
The secondary air is supplied by the pipes that are the pivot points for tilting the burn tubes out of the way. I personally don't use the top load feature.
CZARCAR said:so it seems the incoming,non flaming,cooler/denser secondary air is desceding to reignite the fire?Jags said:CZARCAR said:so the burn tubes keep an active flame at the tube outlets during & after partial reloadJags said:CZARCAR said:IROYAL is top loader? how do secondaries flame?Jags" date="1237943256 said:CZARCAR" date="1237943026 said:=great sounds like u know your stove.
Yep, now of course, this is during relatively hard firing. If I allow it to get almost to the coal stage and the stove top is below ~550, it will loose secondary for a short time, but will pick it back up in pretty short order.
