JP said:BrotherBart said:One advantage I see to cordwood burning over pellets is that you can scrounge and cut and split all of the wood yourself, buy it all or any combination of the two. With pellets you are going to buy it all, period.
While this post doesn't say it outright, i fell like i should mention something that seems to be vailed slightly in all this talk.
i think, on this board, you'll find deep down, and mostly not outright, a strange survivalism aspect. that is to say when the S*** hits the fan, you can toss a chair in your wood stove ala B.J. Honeycut from Mash. In an emergency, be it disaster, end of the world blizzard, whatever, you can burn any cellulose you can find, with no power.
now, this isn't an argument over if this is logical, just something to think about.
Adirondackwoodburner said:yuppers..I think the true woodburner is a rare breed. We are scroungers, survivors and do it your selfers who take pride and satisfaction in hard work. Its a funny thing..You can tell a true woodburner by where they goto relax..It is A. over their woodsplitter B. In a chair with a beer next to their woodpile...
CK-1 said:A wood stove has a better fire and view of it. In my opinion, it also produces more heat. I remember just last year when their was a pellet shortage in my area. Stores showing huge signs that they where out of pellets due to the fact that alot of people where purchasing pellet stove to help heat their homes due to high energy costs. Due to this, pellets went up in prices a few times. I think this year won't be any different..
Goose 1,2 and 4 are true.....Gooserider said:Most of the ground has been covered - but I will try to summarize...
3. Fuel cost and storage - Pellets are expensive, and require "premium" storage - they MUST be kept totally dry, either indoors, in the garage or basement or in a very well waterproofed shed. There have been times when pellets were either not available or VERY expensive. However you are limited in your fuel options, as pellet stoves can only burn pellets or other "pellet size" biomass fuels such as corn. Exact cost comparisons are difficult, but most indications are that a pellet stove will save somewhat over LP or electric, but will be about the same as oil or natural gas. Wood will be less expensive, depending on how much work you want to put into it (note that processing your own does add costs for equipment) and is much less fussy about storage. Many people build woodsheds, but these are low cost structures just to keep the worst of the rain and snow off. Others just throw a tarp or other cover over the top of the pile, or even leave the pile uncovered. Stoves are more flexible about fuels - Ideally you should ONLY burn cordwood, but if you have to, a stove will burn almost anything combustible you can get in the firebox (NOT RECCOMENDED!), even in normal times, while there are preferred woods to burn, you can (and many do) burn any kind of wood they can get into their piles.
4. Work on fuel - Pellets are easy to handle, just pick up a bag and dump into the hopper. Repeat once or twice a day. Pretty neat, simple, etc. Cordwood will be more work to handle, stack, bring into the house, and the stove will probably need feeding more often. If you process your own, then the amount of work goes up greatly, as you may need to bring the wood home, cut it into stove length rounds, split it, etc. OTOH, if you process your own wood, I'll just about guarantee that you won't need to go to the "health club" for exersize.
5. Maintainence - Pellet stoves are much more maintenance intensive. You will need to regularly scrape out the burn pot, the stove will need frequent cleanings (typically weekly) and other service. A Pellet stove has a lot of complex moving parts and electronics, all of which are prone to expensive failure, often requiring expensive service calls from the stove shop. Like a pellet stove, a wood stove will periodically require ash removal, probably more often than the pellet stove does, but otherwise requires minimal maintainance beyond having the chimney swept once or twice a year (This is something that many people get a pro for, but you can do it yourself and save a lot, it usually isn't hard.) Aside from possibly a blower, a woodstove has very few moving parts, and those are pretty reliable.
6. Ambiance - As said, a pellet stove is about as much fun to watch as a bunsen burner. A wood stove will give you a real fire, and some of the secondary combustion tube style stoves will really give a great light show.
The decision is up to you, as the different factors have different levels of importance to different people.
Gooserider
Tammy said:The 2 rooms we are mainly interested in heating is a 12x22 living room and a 12x12 dining room right off the living room with a double door entry. All new windows downstairs. All newly insulated. (We have been remodeling the house room by room. And by we I mean Hubby and I. From the studs out to make sure everything is done right. Not one contractor has been in to do any of it I am proud to say!) The living room has the drywall up but has not been mudd 'd and taped as we thought this would be the time to get one put in while its tore up. And do you need a professtion to install a wood/pellet stove or is this something else we can tackle ourselves?
Also we do not have a chimney. We had a new furnace put in when we remodeled the kitchen. The dang furnace ran right up the middle of my kitche lol..it was horrible. So it will have to be all new piping. We do have a corner wall in the living room that looks like the most likely spot to place one. Right next to an outside wall and next to the dinning room doorway. My whole house is just 1000 sq ft. 2 stories and a full basement.
I am thinking that the wood is the way I want to go. But to convince hubby lol..that might take some work. And it sounds that even if we buy the wood already cut and split we will still be saving in the long run over pellets. But storage is an issue. Although we do have room inside our yard by the garage that we could store it. Can you store wood in the basement? We only use it for storage and its dry. Never had any problems with water down there. See..all newbie questions =)
I am on the survivalist list also. I do believe that crap is going to hit the fan and things are going to get nasty. Even if we have only lost power a total of 5 times in the 12 years we have been in this house, I keep thinking that if there is a huge storm we are up a crick if we dont have heat in the winter. Ah...the things we think about huh?
GVA said:Goose 1,2 and 4 are true.....Gooserider said:Most of the ground has been covered - but I will try to summarize...
Gooserider
3
Fuel cost:depends.... I know most here can scrounge and have tools but what about the people closer to the city and the ones that don't have room to season 4 + cords a season out? And as alot here know some people here with chainsaws should not be using them...... Elk know's what I'm talking about......... as well as Harley and Keyman...
One can always call these guy's (I have them saved in my favorites and watch the prices climb all year)
http://www.mywoodenergy.com/2.html I think these guy's are part of OPEC......
Fuel storage last time I checked.... when I pick up my pellets they have been outside in the elements since the spring.... I break down the pallet and bring them inside the house but if one was to have them delivered they could leave them outside for a long time. as long as they are covered they are fine...
I'll add to 4 The person feeding the wood stove needs to know what they are doing to prevent run away fires etc.
5 Goose you just don't seem to understand.......
Alright here is my maintenance procedure for the winter.
1. wake up and top off the hopper with pellets maybe half a bag.
2. Go to work
3. return from work
4. Open up front door scrape burn pot a couple of times, close front door.
5. before going to bed I top off the hopper again
so in a 24 hour period I spend maybe 3 minutes tending/maintaining my bunsen burner...... That heats my whole house..
full cleaning I do about every 25 bags (avg. 25 days)
6. The only one that I've seen that looks like a Bunsen burner are the Quads (no offense)
7. Don't forget that a pellet stove can be turned on when it hits whatever temp you feel cold at.... Where most with a wood burner turn on the old furnace when it hits 60ish for a couple of days...
8. I'll add that zone heater for zone heater pellets still blow away NG in my area especially since NG efficiancys seem to be on the low side....
Goose maybe you should also talk about how clean a modern EPA woodstove or pellet stove can burn as opposed to the old smoke dragons... :cheese:
Your decimal point is off on the cost per million BTU'S ($14 and $10 respectivly)castiron said:Here's the way I see it: pellets cost about $230/ton. Since wood has about 8000 BTU/lb, a ton of pellets is about 16,000,000 BTU or a little over $140/million BTU. Natural gas this year is plentiful and runs about $100/million BTU so natural gas is FAR cheaper than pellets are and modern NG furnaces are also more efficient than are pellet stoves (by the time you take into account duct losses, the pellet stove may be slightly more efficient but the pellet fuel is still 40% more expensive than is NG). Wood (if you scrounge your own as I do) is FREE.......takes time and energy to get it but if you have the tools (small chainsaw and axe) then it's free except for the gas and chains. This summer I scrounged about a cord of hedgewood......highest BTU wood in the world...31 million BTU/cord and I got it for free........that's about 2 tons or $460 worth of pellets....... Also, the prettiest flame, hands-down, is wood. Don't know ANYBODY who would argue with that. Wood takes more tending and feeding but I like it better. Also, pellet stoves consume electricity vs a free-standing wood stove that has no blower and there are more mechanical parts to go wrong with a pellet stove vs a wood stove.
Bottom line: pellet stove fuel costs more than even NG and their flame (pellet stove) is not very pretty and they consume electricity and they have more moving parts that can break so, in my opinion, a wood stove with free fuel beats it hands down any day. Also, the only thing less romantic than a pellet stove flame is that of a coal stove..............put another way: no children were ever conceived in front of a pellet stoves flame or that of a coal burner...... ;-)
