Hello!
I'm just now getting interested in wood burning after having used wood heat about 15 years ago. Obviously things have changed and I've been getting up to speed on the new stove advancements since then. This forum is a great resource!
We have a superinsulated, airtight home and the design heat load limits us to low output stoves. I'd much prefer a longer burn time and this basically leaves the cat stoves with Blaze King and Woodstock being the two leading options. Because the main living area area where the stove will be placed is small, the Woodstock Keystone is the best fit from a footprint standpoint. However, if anyone has other stove suggestions I'm happy to hear them.
There is a quirk in the Keystone install manual regarding the dimensions of the wall shield. The clearance off the back to combustibles is 14.5" with a stove shield and 12" with a wall shield. I'd like the option of a 12" clearance, again because the stove is going in a small space. The problem with the wall shield size has brought up before in this thread, although this is for Progress install: https://www.hearth.com/talk/threads/options-requirements-for-wall-shield.89780/
Basically it states that the minimum wall shield width is 81" and 56" tall. The height is not a problem but a nearly 7 foot wide shield for low BTU stove seems wrong. I've been in contact with Woodstock and they state that this is based on the 36" rule for clearance. NFPA 211 uses 36" to combustibles as a default for non-tested stoves, although this one is clearly tested for tighter clearances. Woodstock also told me combining a stove and wall shield will not reduce the size of the wall shield.
Here's how I think the shield size can be reduced. The 81" is for a 1" air gap. NFPA 211 appears to measure the 36" on a line from the stove corner, touching the edge of the shield and then to the wall. I've attached the figure straight from the 2016 code book. If I want to reduce the width of the wall shield I could just increase the air gap bringing the shield closer to the stove, or increase the thickness of the shield which would have the same effect. This would leave the shielded area of wall the same with smaller shield footprint, correct? Let me know what you think.
