Yes I did read the whole "How Your Harman Works -what your manual doesn't tell you.." thread but didn't find specifically what I was seeking.
Is the fuel provided to the burn pot strictly a function of the amount of time the auger run's per minute or is it also altered by the feed adjuster setting as well? Does the slide plate open a variable amount to allow more of less pellets into the auger for each 2.5 second increment of feed?
I'm finding that when run on Stove mode with the the feed adjuster set to 3 or more and the temperature set at the lowest setting i.e. "1" the stove still outputs more heat than needed to heat our small house to the desired temperature when its warmer than ~30*F. The at that setting the auger will be running at 15 seconds per minute. If I turn the feed adjuster down to about half way between 1 and test the auger runs ~10 seconds per minute and produces enough heat to warm the house ~ 32*F above the outside temperature. I've seen warnings about running such a low fire for a long time period of time leading to erosion of the end of the auger tube and auger itself but hate to waste pellets overheating the house and needing to keep the windows open in November. Perhaps if I run the stove in room temp mode it will ramp down even lower than the minimum stove temp value......but then there's even more worry about fire down in the auger tube neck.
Thanks for all informed replies.
Hugh
Hugh
