Yet Another Mt. Vernon Auger Jam Question
Evo
2
Pennsylvania
I have a 2010 Mt. Vernon that is getting an auger jam error although the auger is actually clear of any binding. It runs forward for a revolution then runs in reverse. I measured the voltage at the sensor at .5 volts while plugged in and the sensor seemed to respond as I blocked the light path. That voltage seems low for a sensor of that sort, at least according to the optek OPB980 series product bulletin. Does anyone by chance know what the correct voltage is suppose to be at this sensor? I'm trying to determine if the problem is the sensor, motor or control board. Does anyone have a schematic or actual service manual for this stove?
You may have to wait untill a quad person gets on here,but I suspect the thermocouple.Motor running in reverse is part of the shut down procedure.
Reactions: chickenman
Thank Bob, I heated the thermocouple with a torch and the millivolts shot up above 15 mV. It looks like it is working.
