Is this normal for stove top temperatures?
Swedishchef
3,275
Inuvik, Northwest Territories
Hi guys
Quick question: whenever I burn, my stove top tends to want to get hot...fast! My thermometer is in the middle of the stove. I end up using a tripod fan pointed at the stove top in order to keep it around 700 degrees. Some times it reaches 850 if I don't turn the fan on. The blower does not blow air accross the stove top so I find it a PITA since all it does is cool my stove pipe instead.
Is this normal?
With my flu gas temps around 400-500 my stove can reach 900 (if it starts to go thermonuclear) without a fan. I don't often let it get that high..perhaps 2-3 times since I have owned the stove. I want my temps between 650-725 max.
Thanks!
Andrew
I would check those temps with ir gun to confirm but it is too hot if correct
I have a Osburn 2000 and manufacturers recommendations for chimney/flue temperature is not to exceed 475 degrees. If using a probe thermometer temperatures should not exceed 900 degrees.
If I read your post correctly Swidishchef, you stated that your stove top temp is 700 degrees. I am burning at the present moment and my Condar Stove Top Gauge is reading 475 degrees and my Chimguard Thermometer is reading 275 degrees. My flue temps are within safe operating temps but my Condar Stove Top Gauge warns me that temperatures beyond 650 degrees is Too Hot!
Unless your Osburn 2200 has different operating temps I would be careful letting your stove reach 850 degrees.
Fredo
Any suggestions for a decent IR gun at a reasonable price?
Fredo: is 275 degrees on the flue not on the low side?
It's funny because the 2300 manual does not mention s flu temperature of 900 degrees. It says "The ideal temperature for these gases is somewhere between 275o F and 500o F. Below these temperatures, the build-up of creosote is promoted. Above 500 degrees, heat is wasted since a too large quantity is lost into the atmosphere"
Nowhere does my manual mention stove top temperatures. Yet I don't think it is possible to have a flu temp of 500 with a stove top temp of 500.....I only get a stove top temperature of 500 when the secondaries are not burning and I have a big pile of coals...
Andrew
You could have an inaccurate thermo meter.
Do you get a burning paint smell at that temperture?
You can check the accuracy of your thermometer by placing in an oven at 350*.
When you blow air over a bi-metal temp gauge it will give you a false reading..your stove is not cooling like you think it is.
Check with a IR temp gun..you will see what I'm saying.
850 is getting up there for sure..but might not be a accurate reading.
Have you ever seen any part of the stove or flue glowing?
You might have to turn all the lights off at night to see on a hot burn.
Swidishchef,
According to my Condar Chimguard Thermometer, 275 degrees is within safe temp limits. As far as probe gauge, I am not familiar with that type of gauge but I mentioned what my Osburn operators manual stated. There are plenty of brothers here on hearth that will help you with probe gauge question though.
As a matter of fact, I am asking raybonz/ray here on hearth about my stove top gauge temperatures because like you mentioned, Osburn does not state stove top temps in operators manual.
Fredo
k9brain: the only time I get a burning paint smell is when I leave (forget to close) the bypass open too long on a reload. I have seen my inner liner of the double layer stove pipe glow red a couple of times...but that's it, never from the stove.
I have never thought about putting the thermometer in my oven..that is a damn good idea! Next time I bake, it's going in!
HotCoals: never seen the stove glow red....that is why I am wondering it is a fair reading.
Fredo: keep me posted to what Ray tells you, I am curious.
A
